Door Swap
Old Dec 31, 2008 | 10:46 AM
sailorjohn's Avatar
sailorjohn
Door Swap
I’m replacing a bent driver side fender and drivers door from a ‘99 E-350 with a good driver side fender and drivers door from a ‘92 E-150.
(I will probably end up replacing all six doors on the van).
On the doors should I pull the hinge assembly off of the van frame and replace it with the door or should I pull the door off of the hinge assembly and leave the hinge assembly on the frame?
Old Dec 31, 2008 | 12:58 PM
Action4478's Avatar
Action4478
On the doors should I pull the hinge assembly off of the van frame and replace it with the door or should I pull the door off of the hinge assembly and leave the hinge assembly on the frame?<!-- / message --><!-- sig -->
__________________
Leave the hinge assembly on the vehicle ,,remove the door only ....
Old Jan 1, 2009 | 06:26 AM
sailorjohn's Avatar
sailorjohn
Well now I've got to ask why?
Old Jan 1, 2009 | 12:29 PM
Action4478's Avatar
Action4478
It is much less time consuming to align the door ,,you can always adjust those as well ,, later if need be...
