I need help ?
Old Dec 30, 2008 | 11:10 PM
794X4F150's Avatar
794X4F150
I need help ?
Basically i have a 79 f150 4x4 with fresh engine,transmission and transfer case. I just recently replaced u joints in front and rear drive shafts and im getting a very bad vibration between 40 and 45 mph. My local mechanic sez its in the drive shaft,u-joints or pinion. Help
Old Dec 30, 2008 | 11:51 PM
cornfedp's Avatar
cornfedp
I do believe your driveshaft should be balanced, make sure it isnt missing a weight on there somewhere. Failing that look at your tires, make sure one didnt slip a belt.
Old Dec 30, 2008 | 11:58 PM
794X4F150's Avatar
794X4F150
The problem didnt start until after u joints were replaced and tires are brand new Cooper Discovery SST.
Old Dec 31, 2008 | 03:40 AM
75F350's Avatar
75F350
Welcome to the site.
It would appear that you may have installed the slip joint(s) in the wrong orientation. It is important that the shafts u-joints are aligned. This is called the "Phase". If you have your shaft out of phase, it will vibrate. Having the shaft back in phase will solve your problems.
You might only be off as little as one spline, and this is enough to cause the vibration.
Here is some good reading.
Again welcome!
http://jniolon.clubfte.com/driveline...nephasing.html
Old Dec 31, 2008 | 03:57 AM
joe f350's Avatar
joe f350
are ur tire blanced it sound like speed woble
Old Dec 31, 2008 | 05:27 AM
fastfarmer's Avatar
fastfarmer
2nd on checking to make sure your drive shafts are in phase. Also make sure that the u-joints are properly seated where they bolt on to the pinion. I've seen one cocked off to the side a bit causing a vibration.
