Stock trans gauge??
Old Dec 30, 2008 | 10:22 AM
04redstroker's Avatar
04redstroker
Stock trans gauge??
Just wonderin how accurate and reliable it is, should i spend the extra money when do boost and pyro, and replace with aftermarket?
Old Dec 30, 2008 | 10:52 AM
jmaskew's Avatar
jmaskew
I would add a trans if you are purchasing gauges. The stock trans gauge hits it's halfway stationary position at 50 degrees... useless if you ask me. I would do oil or coolant temp also or both if you can.
Old Dec 30, 2008 | 11:44 AM
p8ntballn2's Avatar
p8ntballn2
yea.. the stock trans temp gauge is garbage.. if that thing hits "HOT" its too late.. you've already damaged something.. kinda like a dummy gauge
Old Dec 30, 2008 | 07:15 PM
04redstroker
Thats what i figured. We toasted a tranny on a truck at work, and the gauge never moved.
Old Jan 1, 2009 | 11:20 PM
Stroked Out!'s Avatar
Stroked Out!
Yeah Same Here I Had A Secondary Trans Gauge Blow Out Of The Port And Lost Fuild Barely Made It To The Shop And The Stocker Didnt Move A Bit, It No Good Dont Trust It!!!!
Old Jan 2, 2009 | 08:38 AM
69cj's Avatar
69cj
Stroked out, The temp sender needs fluid to read temp. If all fluid leaked out the gauge has nothing to read. I'm not saying the gauge is good, just stating a fact.
