4.9 intementent miss
Old Dec 29, 2008 | 09:42 PM
73f-1's Avatar
73f-1
I have a 87 f-150 4.9efi 4spd no a/c. Sometimes at idle it starts missing,I can smell fuel,but does not smoke.It will buck while driving.It does it 75% of the time,sometimes it drives great to and from work without missing a lick.New plugs, fuel filter,checked and replaced all vacuum lines.It code an egr code,I put a blockoff plate between it and the intake,no change.Tested fuel pressure read 57-60,didn't drop when missing(haynes manual says up to 60 ok on all exept for 87 model,but the fuel pressure regulator part#is same for the other years).Please help,Thanks.
Old Dec 30, 2008 | 11:50 AM
Lazy K's Avatar
Lazy K
I think the first thing you should do is to go to fordfuelinjection.com and click on Fuel Pressure Regulator and read. Good luck.
Old Dec 30, 2008 | 12:53 PM
quicklook2's Avatar
quicklook2
how old are the ignition wires?
Old Dec 31, 2008 | 09:20 AM
73f-1's Avatar
73f-1
The wires are three years old 12,000 miles
Old Dec 31, 2008 | 09:29 AM
73f-1's Avatar
73f-1
I'm going to check the cap,button,wires,fuel pressure regulator,and coolant temp sensor.will let you know.
Old Dec 31, 2008 | 09:55 AM
quicklook2's Avatar
quicklook2
what brand and type of plugs?
Old Dec 31, 2008 | 10:29 AM
wolfy's Avatar
wolfy
check your distributor cap and rotor inside, a lil bit of moister will foul those up. also on my 91 4.9 I6 i simply unhooked the vacuum line to the egr valve and it stopped the bucking / hesitation during light throttle. you might want to give that a try.
Old Jan 2, 2009 | 11:00 PM
73f-1's Avatar
73f-1
Motorcraft copper core plugs.I unplugged the fuel pressure regulator hose and it smells like gas,I guess that diaphram is busted.I'll put one on it payday along with a cap button and new plugs.I will let you know.
Old Jan 3, 2009 | 04:10 PM
johnson93gt's Avatar
johnson93gt
does this truck have a speed sensor?in the rear end? my truck was acting crazy and that was it just an idea
