Firestone Ride Rite Air Bags
Old 12-29-2008, 08:41 PM
Bud-150's Avatar
Bud-150
Bud-150 is offline
Has anyone installed ride rite air bags on the f-150's? Is there any drilling required? Where would be the cheapest place to get the Firestone air bags?
Old 12-29-2008, 08:51 PM
Tylus's Avatar
Tylus
Tylus is online now
MMNC (SS)(Ret)
do a search
quite a few guys here have them and I've heard nothing but + things
Old 12-29-2008, 09:17 PM
mattd17's Avatar
mattd17
mattd17 is offline
i have them.... they are AWESOME !!! install is super easy. what year is your truck? the 04-08's do not require any drilling. the install will take about 30 minutes for the first side, and then half that for the second. although not required, i would recommend also getting a compressor kit. yes, it will double the cost, and probably quadrouple the install time, but WELL WORTH IT IMO. i bought mine from 4wheelparts a couple years ago, and i paid about 450 for the bags and compressor kit.
Old 12-29-2008, 09:20 PM
DonsFx4's Avatar
DonsFx4
DonsFx4 is offline
Bud..I had em on mine. Very easy install, no drilling required. I had the left/right plumbed together and a single air valve...this way pressures would be equal on both sides.
I got mine off of e-bay ("Performance Suspensions"??) and they were pretty inexpensive (apprx $200). They worked great for the little time I had them installed before I had to sell the truck due to job insecurity...big mistake in retrospect!
Old 12-30-2008, 09:23 AM
laketrout's Avatar
laketrout
laketrout is offline
I have them on my 02. They did require some drilling, took about 1.5 hours to install. They are awesome for pulling my boat.
I got mine from Summit, $215 shipped.
Old 02-09-2009, 02:50 PM
cgah04's Avatar
cgah04
cgah04 is offline
just installed a set today.. went fairly easy.. did it in the driveway so it was kinda a pain in the butt.. pretty easy kit to put together..
Old 02-09-2009, 03:10 PM
diesel_dan's Avatar
diesel_dan
diesel_dan is online now
Ditto on Summit Racing. I have the Air Lift bags and would go with the Firestones next time. When you compare the two packages, the Air Lifts have thinner lines and all plastic fittings, the Firestone has brass fittings and overall looks like a better built and better value set up.
