smokey 99
Old Dec 29, 2008 | 09:18 PM
hucka1a's Avatar
hucka1a
My truck does this from time to time. It smoked a little today. Just like you said, at low rpms. I went WOT from a rolling stop to about 60-70 mph twice. It hasn't smoked since. I just figured where I normally drive conservatively, it just needed a good run.?
Old Dec 30, 2008 | 07:18 AM
zx250's Avatar
zx250
Of the next Riffraff East
Originally Posted by F350-6
You got it backwards Barry. A little up and down is ok as long as it doesn't touch the housing. In and out play is no good.
Yeah, saw that after my edit option was up. But hey, I'm backwards a good bit of the time.
Old Jan 3, 2009 | 06:12 PM
dawg 21's Avatar
dawg 21
I tried that a few times this week i'm gona change the turbo next weekend
How much should a rebuilt turbo cost??
How long does it take to change one??
thanks Dave
Old Jan 3, 2009 | 06:43 PM
PaysonPSD's Avatar
PaysonPSD
thanks Dave
Make sure your turbo is bad before replacing it.
If you need to replace or rebuild the turbo Ron's Turbo Service has turbos and rebuild kits. He is well respected, has good pricing and answers the phone if you have questions. Ron's Turbo Service
If you have never replaced a turbo before it is a guess as to how long it would take.
Old Jan 4, 2009 | 09:41 PM
dawg 21's Avatar
dawg 21
I don't know if the turbo is the problem but it moves in and out about a 1/2 inch at least so I'll start there if it's not the problem I'll head for the injectors thanks for all the help I'll keep you guy's posted
Thanks for all the help Dave
Old Jan 4, 2009 | 09:49 PM
mongo75's Avatar
mongo75
Dave, I've rebuilt my turbo once, but removed it twice due to loose exhaust housing.... anyways I got it down to where I can pull it in under 20 minutes. The worst part is taking the damn v-band clamps off the y-pipe. Use plenty o' PB Blaster or WD-40, and drink about 2 beers before you try to remove that clamp. Even them you'll probably need a hammer and long screwdriver. Good luck!
Old Jan 4, 2009 | 09:59 PM
dawg 21's Avatar
dawg 21
Thanks for the advice I'm gona try to change the turbo next sat. I'm gona get a remaned. turbo from superior diesel in Detriot wish me luck and Ill take all the sugestions you guy's have
Old Jan 4, 2009 | 10:18 PM
mongo75's Avatar
mongo75
IF you haven't ordered it yet, it really only takes like, 20 minutes TOPS to rebuild a turbo once you got it out. Just food for thought......
Old Jan 6, 2009 | 04:43 PM
dawg 21's Avatar
dawg 21
I was thinking after looking at the turbo that looks lika a crappy job to remove it what if I remove the engine the oil pan looks like crap and it looks like the motor needs to come out to change that or can it be changed with out removing the engine???
Old Jan 6, 2009 | 08:13 PM
mongo75's Avatar
mongo75
Dawg, do a search for oil pan fixes. Most folks would try to seal the oil pan with POR-15 first, which I believe is sort sort of 2 part epoxy sealant, but don't quote me. Most swear by the stuff as it's a helluva lot easier to clean and paint the pan instead of cutting frame cross members or pulling the block....
Old Jan 6, 2009 | 08:45 PM
dawg 21's Avatar
dawg 21
epoxy the oil pan does that work or is a quick patch I don't like to fix things again I'll check into the epoxy as far as cutting the cross member out thats not going to happen I did see the guy's picture's who did that with his dad's help it looks like it came out nice enough but I just could not cut my truck in half I will check into the epoxy
I see you pulled your turbo in 20 mi. maybe I'll try going that way
Thanks again Dave
Old Jan 15, 2009 | 04:58 PM
dawg 21's Avatar
dawg 21
Just up dating you guys we put the new turbo on last week end and its running great
Thanks for all the help you guys are the best
Dave
Old Jan 15, 2009 | 05:01 PM
  #28
zx250's Avatar
zx250
Good to hear Dave. How bad was the old one worn?
Old Jan 15, 2009 | 05:18 PM
  #29
dawg 21's Avatar
dawg 21
it moved in and out about 3/4" it was leaking oil into the engine the base was leaking too so we rebuild it too I think thats were the oil leaking out of the engine was coming from
Dave
Old Jan 16, 2009 | 12:54 AM
  #30
4inchlovin's Avatar
4inchlovin
Good to hear thanks for the update!
