Sponsored by: Real Truck
Another "What's That Noise" Thread
Old Dec 29, 2008 | 11:19 AM
bluestuff's Avatar
bluestuff
2004, F250 SD, KR, 6.0 PSD, Fx4 w/Off-Road Pkg, 48K miles, no mod's.
I pulled a 9,500# load Saturday for the first time.
At average speed of 50mph, periodically heard a noise sounding like the radiator fan kicking on. The sound would go off-on-off sometimes for just a few second cycles, other times it would stay "on" for a minute or so.
Is it just the cooling fan?
If so, why would it "fast-cycle", and not stay on longer?
If not, what was it?
Old Dec 29, 2008 | 12:36 PM
ReAX's Avatar
ReAX
The cycling makes it sound like the AC compressor. The AC is active during AC (duh) and when you use the defroster (to dry the air a bit). The engine coolant fan should have a thermostatic clutch of some kind. If the air temps were low, I could see where the clutch would lock and unlock as it cooled off.
Old Dec 29, 2008 | 06:43 PM
BillyBob69's Avatar
BillyBob69
It sounds like the cooling fan for the radiator. With the weather temps being lower this time of year, it shouldn't be kicking in unless you are hauling a heavy load and really heating up the engine. I would first check coolant levels to make sure you aren't low.
