1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Another 4wd issue
Old 12-29-2008, 05:39 AM
Downriver Thunder's Avatar
Downriver Thunder
Downriver Thunder is offline
Another 4wd issue
I had my satellite radio re installed yesterday and when the guy was pulling it out of the shop I noticed my front driveshaft spinning. Now, the switch is in 2wd and the hubs in auto, any ideas?
Old 12-29-2008, 08:04 AM
powerstroke72's Avatar
powerstroke72
powerstroke72 is offline
Sounds like the stereo installer tapped into one of the ESOF wires to me. May have to pull the panel to see but he definitely did something. Try turning the SAT radio off and see if it goes back into 2WD.
Old 12-29-2008, 12:41 PM
ReAX's Avatar
ReAX
ReAX is offline
Or it could be as simple as the transfer case motor didn't take it all the way out of gear. Try tapping the motor with a mallet while switching out/in 4wd.
Old 12-29-2008, 01:17 PM
Downriver Thunder
Starting to wonder about this truck. I noticed today that with the hubs in auto that they still clunk a bit while cutting a hard turn. I know my ole Scurge didn't do that in Auto.
Old 12-29-2008, 02:49 PM
Fordfanatic4life's Avatar
Fordfanatic4life
Fordfanatic4life is offline
sounds like the hubs might not be fully disengaging ...
time to service them me thinks...
Old 12-31-2008, 10:28 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Sounds more like the axle stub needle bearings are dry.
Reach around the back of the front wheels and try to rotate the axle u-joint by hand. If it's gritty or ratchety, the needle bearings are shot.
If they just will not move no matter what, remove the hubs and see if they are stuck. It's not too hard to get the hubs out, but you might need a rubber mallet.
