sixing
Old Dec 28, 2008 | 09:58 PM
sixing's Avatar
sixing
sixing
Problem w/charging system- 91 ford e250 300 six, I think it has an ammeter, not light, guage that reads charge or discharge- problem started when battery went dead while driving, replaced alternator and regulator, battery tested OK, started up and no charge, full fielded alternator and charged @ max, I think this is a problem with excite wire that goes to S terminal from regulator, anyway is it possible to abandon this wire and run a new one from a switched circuit "on when key is on" and do I need a resister ? any help will be appreciated, Thanks
Old Dec 28, 2008 | 10:57 PM
pfogle's Avatar
pfogle
Are you sure it's not charging? Have you hooked a VOLT meter to the battery and verified that you're not getting 14.4 volts? The ammeters tend to fail and not show a charge. If you're going by that alone you need to check into it further before assuming it's not charging. I've owned several from '83 to '89 and I think TWO of them had working ammeters. That was it.
Old Dec 28, 2008 | 11:15 PM
sixing's Avatar
sixing
Yes I checked w/ voltmeter and seen voltage dropping w/brights and AC on "dropped from 13 to 11.5 volts.
Old Jan 8, 2009 | 03:32 PM
maples01's Avatar
maples01
Check our change the ground straps, both the batt to body and engine to body, they tend to corrode and fail with time, causing charging problems.
