idle 460
Old Dec 28, 2008 | 05:23 PM
fzeed's Avatar
fzeed
Question idle 460
My idle is set to the specs that are on a label on the valve cover. But 650 RPM doesn't seem to be much. Just curious what other people have their 460's set to. Mine is stock except for an Edlebrock 4 barrel (600 or 650 CFM, don't remember)
Old Dec 28, 2008 | 05:29 PM
garlindethfury's Avatar
garlindethfury
With an aftermarket carb you will have to just tweak it until you get the truck idling smoothly and to your liking... every truck will have a slightly different setting cause not all motors are the same... So just play with it untill it is how you like it...
Old Dec 28, 2008 | 05:32 PM
fzeed's Avatar
fzeed
well, i'd like it to be able to idle down the road. Or when you take off from a lite it moves a little bit on its own. Right now it sits still at a light until i give it gas. I just don't know what to set it to. How much is too much?
Old Dec 28, 2008 | 05:42 PM
garlindethfury
generally keep it below 1000 rpm and you should be good...
Old Dec 28, 2008 | 06:42 PM
52 F3's Avatar
52 F3
Sounds like it must be an auto trans. If you have to use much brake to hold it at a light you won't like it if you get on slick roads.
