Busted spark plug in head
Now, let me ask this. What is a realistic estimate for a shade-tree mechanic like myself to pull the driver side head?
This should work....follow the link. Crappy photo, sorry.
http://www2.snapfish.com/slideshow/A...63/t_=43016763
The plug above the shattered one is the second plug I took out. It broke at the porcelain, above the nut. Should have quit while I was ahead.
I'm thinking EZ-out...or LH-threaded bolt of a slightly larger diameter than the hole in the center.
At least you know now what the bang was--the pocelain coming out, and the "rattle" was the engine running with a hold where a spark plug should be. I've driven a vehicle quite a ways missing 1/8 plugs before--it's pretty loud.
Jason
I used a large easy out and a torch, heated them up nice first then used the easy out. Got all four out no problem, I can post a picture and size of the easy out if needed.
I wouldn't pull the head unless everything else fails to remove it/them. The porcelain was likely blown out the hole rather then sucked in, the compression from the motor running would be much stronger then the vacuum could ever be. That and the ground electrode would help keep it from being sucked in.
Get new plugs in it and go from there, you'll know if any damage was done. If any doubt put a vacuum gauge on it and check for a steady needle.
I've never run an engine with a plug hole open before so maybe what I heard was what you described. The sound was probably pretty distorted considering that I was in the truck with the hood and door closed. I'll re-evaluate in the morning.
It is the third plug from the front on the driver side so it is fairly accessible. Any pictures and suggestions on getting the threaded part of the plug out would be great.
Says,
EX.5
USE 19/64 DRILL
<br>Here is one to give you a idea of its over all size,<br>
Do not break one off in the hole, use heat first and get what is left of the plug good and hot then use the easy out. If it doesn't move heat it again, have what you're going to use to turn the easy out with ready to go.
Give the easy out a couple of taps with a hammer to help it bite in before trying to turn it.
I can't stress enough how important it is you do not snap the easy out off in the hole, keep in mind easy outs are hardened steel and are brittle, they do not flex, tend to snap fairly easy.
Take your time, use plenty of heat, and you will get the pieces of plug out of the hole.
Oh and make sure the piston is down in the cylinder, not at tdc, to be sure the easy out doesn't hit it, not sure it would but be safe rather then sorry.
Anyway, I didn't feel like pulling the torches out so I plugged the hole in the plug and soaked the plug base in Kroil (the best stuck bolt stuff IMHO) and went and changed the oil on my Escape. Came back a while later, tapped in the drill and wrenched on it and out it came. When it broke free I think I re-injured my elbow (had surgery last Jan) but at least the plug is out.
Now all I have left is to try to blow out the cylinder. I have it at TDC on the compression stroke and hopefully anything in there will come out the plug hole. At this point I believe nothing is in there. Once I put the new plug in and reinstall all the crap I took out of the way, I plan on getting drunk and then fire it up. I'll either be celebrating my luck or drowning my sorrow....
Thanks a bunch for all the help and advice. I owe you all a cold one....
By the way, the engine rebuilder told me I was probably looking at $600 (one full day of labor) or so to have him remove the head, remove the plug and reinstall. That was with no other work. Less than I thought to be honest.
Now again I don't know what your noise sounded like, but with the ground end of the spark plug hanging under the elctrode, its more likely it blew out then fell in.
Anyone have any thoughts about why the no-fire condition? Is it bad to run with only three new plugs?
I plan on driving it to work tomorrow to see how it starts cold and how it runs overall.
I've run two new plugs and two old plugs in my old Courier while I was waiting for the PB Blaster to work. I could feel the difference in the engine, probably what your slight miss is.
Glad to hear you're okay!
I was pretty certain that merely idling, for a few seconds, with a piece of porcelein (which is lighter and much more fragile than steel) in the cylinder is not enough to GUARANTEE you'd have a cracked head; I'm sure it's possible, but I think it's far from a "definite" outcome. I suspected your head would be intact, though it may be pock-marked a little, at worst.
Keep in mind that some companies sold a "tire pump kit" which actually required you to run the engine with one plug missing--no kidding! You removed one plug and used that cylinder as an AIR COMPRESSOR, to pump up your vehicle's tires. I guess the small amount of gasoline in the cylinder did not worry anyone, though it seems like a bad thing to permenantly inject into rubber tires, as gasoline attacks rubber.... I believe the kit was sold by Sears, but cannot swear to it. My Dad had one in our 1960 Falcon. My point is, it won't hurt the engine to have run a few seconds with an open cylinder.
Though I've never used one, I would suggest to anyone in this situation that a boroscope could be rented, or even bought (I've seen them for under $250. on tool sites like this one: boroscope from Northern Tool + Equipment )
IOW, I would look into the engine before I ever pulled a head, in such a situation, which I would only do if I felt there was no other recourse.
Again, I'm very glad it worked out for you; I have the identical truck, with a 5 spd., and I think the P.O. only changed the plugs once--I pulled one out and it did not come willingly, so I fear I may have similar problems.
Happy New Year!
BigSix
