Three Gauge Pod Insallation ???
Old Dec 27, 2008 | 11:42 PM
7.3_powerstroke_7.3's Avatar
7.3_powerstroke_7.3
Exclamation Three Gauge Pod Insallation ???
Hi ! i just bought a three gauge pod that goes on the left pillar beside my windshield, can anyone plz help me with the installation, how can i make it hold there tight ?
Thanks !
Old Dec 27, 2008 | 11:46 PM
Tenn01PSD350's Avatar
Tenn01PSD350
It's really easy, follow the instructions and use the supplied hardware. Did it not come with instructions? There are a bunch of links to the install for these.
Old Dec 27, 2008 | 11:47 PM
7.3_powerstroke_7.3
no i never got any instruction in the box hehe !
Old Dec 27, 2008 | 11:48 PM
Steve_250's Avatar
Steve_250
Here is just what you need....
https://www.ford-trucks.com/forums/3...my-gauges.html
Old Dec 27, 2008 | 11:49 PM
crum71's Avatar
crum71
1/8 mile Oval Track
Gauge Installations at DieselManor- 1999-2003 7.3L Powerstroke
Old Dec 27, 2008 | 11:50 PM
Tenn01PSD350
Where'd ya get it from and did you get the proper push plugs? We can get you there but without the proper hardware you may be stuck for a bit.
Zip's Avatar
Zip
I just bought one as well. Mine came with 4 of those kind of push in screws to hold it secure. Mine fits over the existing pillar. I thought of using some double face tape instead so I don't have to drill any holes in my pillar.
Old Dec 27, 2008 | 11:53 PM
crum71's Avatar
crum71
1/8 mile Oval Track
My bet would be,that they came from the same place that JD got his. He didn't have any wiring at all,so we just made some.
Old Dec 27, 2008 | 11:56 PM
Zip's Avatar
Zip
I bought mine off of Craigslist. Original purchase was from Diesel Manor.
Old Dec 28, 2008 | 12:01 AM
Tenn01PSD350
Makes me ask, are you selling the truck anytime soon? If so, or even not, are you planning on removing the gauge pod and selling that separately used? Not going to get much so unless you plan to put it in the next truck, not worth it.
So this is drill apprehension. Measure twice, mark and line up, check again, then just drill it. But to answer the question, folks have installed their pillars with DS tape or emblem adhesive. Problem is, it's a PITA to remove if you need to.
Old Dec 28, 2008 | 12:04 AM
Tenn01PSD350
Diesel Manor site instructions are posted here. Pretty good one too from what I recall. Problem is when you don't get all the hardware, wiring and senders.
Old Dec 28, 2008 | 12:17 AM
Zip's Avatar
Zip
No not in the near future. Haven't even installed the gauges yet.
Exactly what it is, drill apprehension. I just hate drilling holes. I guess it's not a big deal since I plan on keeping the truck.
They are very good instructions. As for wiring and senders I got the whole meal deal. Three boxes for the gauges, another two boxes with stuff for the exhaust gauge, a box of tubing and a bag with about a million clips and wires etc.
Old Dec 28, 2008 | 12:38 AM
Tenn01PSD350
You'll be fine Chris. Look in my gallery for my gauge pod install oopsie and try to avoid that. Just do it.
Old Dec 28, 2008 | 07:50 AM
DieselCamper01's Avatar
DieselCamper01
I only drilled one hole at the upper right corner and mine holds fine. I also routed my wires and such BETWEEN the existing pillar cover and the dash. There is NO reason to drill through the existing cover to run the wiring. I believe most or all the directions tell you to drill but it is not required. My .02. End rant! lol
Old Dec 28, 2008 | 10:42 AM
Ponyboychris's Avatar
Ponyboychris
I drilled two holes on the top of the pillar to hold it in place using the push pins. The black weather strip of the door covers most of the push pin head as well. The other is wedged up against the windshield and you cannot see it. The bottom of the pillar holds tight because of the dash. Been in place for three years without an issue.
On edit: I have 2 extra push pins if anyone needs them.
