from big blockto small block
Old Dec 27, 2008 | 10:30 AM
Bugk's Avatar
Bugk
74 Ford F100
<HR style="COLOR: #d1d1e1" SIZE=1><!-- / icon and title --><!-- message --><TABLE width="100%" border=0><TBODY><TR><TD vAlign=top>I put a 351W engine w/auto tranmssion into a 74 Fordpickup that had a big block engine.(blown390)
Problem: the crossmember didnt align and the drive shaft came up 3in to short.
the small block running gear wasnt factory too but it came out of a 75 F100 truck same wheel base as the 74
Q: is there an adapter to shift everything toward the rear of the truck 3in? or will i have to adapt the linkages and lenthen the drive shaft?
any comments ,emails or suggestions welcome Thanks
</TD></TR></TBODY></TABLE>
Old Dec 27, 2008 | 10:36 AM
75F350's Avatar
75F350
How much firewall clearance do you have? It appears that you have used some engine mount that has the entire engine and trans too far foward. These frames have several sets of holes for the mounts to bolt to. Did you use a set that was too far foward?
You may have to get creative here, but it seems reasonable that moving the engine and trans back would make everything line right up.
How did you actually mount the engine?
That FE engine is just that by the way, an FE and not a BB. (just a point of clarification, and maybe being a little too critical)
Old Dec 27, 2008 | 11:45 AM
Bugk's Avatar
Bugk
Thanks for the quik reply.
I have lots of firewall clearance, I did not change the original mounts from the 74 that held the 390...
I mounted it on the mounts that came with the 74 they appeared to be identical to the onset in the 75 truck.. does someone have an adapter or offset brackets ?
Old Dec 27, 2008 | 01:08 PM
Supercab's Avatar
Supercab
Wink
You need to change the MOUNT SUPPORTS (also called perches) to the small block ones from what ever truck you took the 351W out of, and everything will then line up perfectly as long as you use all the running gear from the donor truck-you may have to change the driveshaft yoke to the one for the small block application.
Old Dec 27, 2008 | 02:39 PM
Bugk's Avatar
Bugk
re
GREAT
I they looked the same when I first looked ,it may have been an oversight on my part.. This will be an easy fix if you are right.. thanks again God Bless!
