Wanna Trade?
Old Dec 28, 2008 | 07:30 AM
fellro86's Avatar
fellro86
When I test my glow plugs to be sure, I have 12 v at the plugs... right or wrong, that's what my meter shows. I don't have a truck with the newer controller to see what it puts to the gp's. So I was going on what I had been told elsewhere, which I can not validate or deny... It might be they use different resistances due to the change in glow plug powering...
Old Dec 28, 2008 | 01:53 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Actually all the 6 volt plugs do in a 12 volt circuit is heat up faster.
The new style system also puts 12 volts to the glow plugs.
The relay in both systems is interchangeable, the difference is the new style system has the controller mounted below the relay.
Since the wirng harness is the same wire size in both the new and old style systems, the voltage drop will also be the same when all the glow plugs are hooked up.
GJWallace
30
Apr 15, 2016 07:38 PM
volumetricefficiency
17
Oct 29, 2009 10:55 PM
JakeSherlock
27
Apr 17, 2009 11:16 PM
knash0727
Dec 14, 2007 06:59 AM
Wolverine69
21
Dec 28, 2006 09:04 AM
