sway bar endlinks
Old Dec 26, 2008 | 09:22 PM
primas75's Avatar
primas75
sway bar endlinks
I have a 2001 expo eddie bauer with 78k on it and one of my sway bar end links is not attached. I have started to get a vibartion at 55 and gets worse as the speeds goes up. Do u think i need a balance or can these be caused by the endlinks needing to be replaced. Also my passager side cv axles is leaking grease and i have bought the parts to fix it and the end links.Mine right now i have 24's on it and it just started since i found out that i needed a sway bar
Old Dec 27, 2008 | 02:24 AM
alloro's Avatar
alloro
The vibration is due to an unbalanced tire. Fixing the end link will help prevent leaning while cornering, nothing else.
Old Dec 27, 2008 | 07:57 AM
MisterCMK's Avatar
MisterCMK
Like alloro said, the end links will not fix the vibration. Have your wheels/tires balanced to fix that vibration. If the CV is bad enough it could be causing the vibration as well.
Old Dec 28, 2008 | 08:49 PM
primas75's Avatar
primas75
ok thanks the cv is not that bad the boot just needs replacing.
AGrayson84
Oct 24, 2016 10:21 AM
Chevmn56
30
Nov 1, 2015 07:51 AM
ahargrove
Mar 17, 2014 07:50 AM
X-70STANG-F150
Jul 27, 2009 07:41 AM
JSPajak
Oct 22, 2007 10:22 PM
