Wanting to build a 351w with 300 to 400 hp
Tri-State Cylinder Head - Chevy, Ford, Small Block, Performance, Aluminum Cylinder Heads
If you don't want to spend a wad of money in heads.
Hmmm... A little less HP than the book listed, but the torque is right on. My desktop dyno is pretty crappy and I haven't spent much time with it, or gotten any cam software for it. It usually specs out a little more HP than reality, IMO.
I hadn't thought about running that build through my desktop, but when I did it spit out the torque curve that looked exactly identical to yours, but about 410 HP at a little higher rpm peak.
I have to plug some pretty generic stuff into mine, (especially the cam and heads) but between your dyno and mine, I can believe the 390ish HP they claimed is possible.
I have also thought that was a little high for the parts, but gave them the benefit of the doubt. They actually listed a XE282H as well, but listed the XE262H and referred to another build with the XE262H as the same cam, so it's possible that it should be the XE282H and that may boost the HP on your dyno.
It's obvious that one of them was a typo, but maybe it was the 262. If you have some time to kill and feel so inclined, try punching in the XE282H and see what HP it pops out.
In case this doesn't make sense to you, this is the build I cited in the "HOW would you build a 351W" thread.
Oh- and try punching in open headers, I doubt they ran mufflers on the dyno.
If you're at all serious, you'll go with a stroker crank and a roller cam. I didn't see what RPM you wanted to make this horsepower at, but because it's a truck, I'll assume you want it at the lowest possible RPM. A 408 stroker can make 350 HP and better than 400 ft/lbs of torque.
GT40p heads aren't going to be the best choice. I'd be looking at C9 or D0 heads or similar and I'd be doing a home port and putting in 2.02 valves.
You can do it, but you have to be smart about it. Again, a retro-fit roller cam is the way to go. Get your heads and displacement figured out and then get a custom cam designed for the head flow.
on
I'll give that a go when I get the chance. That cam above is the XE262H, so I expect the XE282 will indeed make more hp but at the expense of low rpm TQ.
The 450hp 302 lists a Comp Cams Extreme Energy 282 hydraulic roller in both the description and parts list.
The 395hp 351W lists an "aggressive flat tappet hydraulic camshaft from Comp Cams" in the description and "Competition Cams, specs unknown, Aggressive hydraulic" in the parts list.
ok I am going with the 393 stroker kit now I am prbably going to bore th cylinders .030 over. for the top end I was going to use eldebrocks power pachage top end kit 400 hp 412 FT. LBS. OF TOURQE PART NUMBER EDL-2092 now would this be a alright. I would like to see what the numbers would be like on the desk top dyno but I dont have . well tell me what you guys think and info will help.
Most carb sizing charts will list 600-650 CFM for 400 ci. for stock to mild performance and 700 CFM+ for racing.
#28
