Sponsored by: Real Truck
2004 4x4 Problem
Old Dec 25, 2008 | 07:21 PM
Mr Mach 1's Avatar
Mr Mach 1
2004 4x4 Problem
I have a 2004 f250 SD w/4x4 on the fly. It will engage then about after a couple miles 4wheel drive seems to stop working. I can turn it off then back on and it will start working again.
Old Dec 26, 2008 | 12:37 AM
Monsta's Avatar
Monsta
Sit. Stay.
...only to shut off again?
Sounds like a vacuum leak at the hub. Have you serviced your hubs at all since you've had the truck?
Old Dec 26, 2008 | 08:31 AM
Mr Mach 1's Avatar
Mr Mach 1
No I haven't. I bought the truck last year and the 4x4 worked fine. How do I sevice the hubs?
Old Dec 27, 2008 | 02:04 AM
Steve_250's Avatar
Steve_250
Engage 4X4, turn on your heater. Does it blow defrost no matter what?
If so, you have a vacuum leak. Check your lines to the hub from the right fender well.
Lock them manually at the hub, do they work?
Yep, prolly vacuum.
Other than that, maint on the hubs is here:
Welcome to guzzle's Ford PSD Maintenance Web Page
Old Dec 27, 2008 | 07:10 AM
Mr Mach 1's Avatar
Mr Mach 1
Yep, prolly vacuum.
Thank you! I will check this out.
