New Alternator
Old Dec 25, 2008 | 10:26 AM
calf roper's Avatar
calf roper
New Alternator
Put my new alternator in last night and also the 250 amp in-line fuse from DB.I mounted it on the air filter housing. I am not sure how to post a pic so I used my Kodak album.Please let me know if it worked and if this is OK to do on the site. Carl Kodakgallery.com: Slideshow
Old Dec 25, 2008 | 11:26 AM
F350-6's Avatar
F350-6
The link worked. That looks good. The DB should take care of you.
Old Dec 25, 2008 | 12:43 PM
strickracing's Avatar
strickracing
looks good
Old Dec 25, 2008 | 06:03 PM
87 F-150 I6's Avatar
87 F-150 I6
Nice, always good to upgrade!
Old Dec 25, 2008 | 09:47 PM
megawatt00's Avatar
megawatt00
Looks good you can't beat a DB!
Old Dec 25, 2008 | 10:16 PM
jdecker88's Avatar
jdecker88
Is that all you had to add to upgrade to a bigger alternator?
Old Dec 26, 2008 | 12:00 AM
BobbyDiesel71's Avatar
BobbyDiesel71
was the install easy?
did you just have to install the inline fuse to the POS battery post?
all other wiring just stock?
Old Jan 5, 2009 | 08:31 PM
calf roper's Avatar
calf roper
Sorry I did not see this sooner.The install was super easy.Took all of 5 min on the alternator.The fuse block took a little longer,Had to cut the cable and put the connectors on.The fuse block is not required but is a good safety play.If you have any short or over load it takes care of it.Hooked it to the Pos. on battery.You could go either side.I had more room on the left.
Old Jan 5, 2009 | 08:35 PM
megawatt00's Avatar
megawatt00
To me the fuse is a necessity.
