Motor swap quickie
Old Dec 25, 2008 | 12:22 AM
1ole4d's Avatar
1ole4d
Motor swap quickie
How hard would it be to install a 351W in a 1970 F100? Are the motor mounts the same? I have a guy who wants the 302 out of my truck and is offering to trade me a 351W for it.
Old Dec 25, 2008 | 12:38 AM
wizzard351's Avatar
wizzard351
pretty much a direct swap the only difference is the brackets(ie. alt,ac,ect,ect) and the exaust Y-pipe wont work. the manafolds will work but the Y-pipe wont. engine mounts are the same and so is theflywheel and bell
Old Dec 25, 2008 | 05:03 AM
jowilker's Avatar
jowilker
I agree wid da wizz, should be a direct swap. Can't advise on exhaust issues though.
John
Old Dec 25, 2008 | 01:03 PM
limegoldf100's Avatar
limegoldf100
I did this swap into a 71 F-100 which came new with a 302. Absolutely everything is the same except that the extra height of the 351W spreads the exit location of the exhaust manifolds as compared to the 302. My engine came from a 75 Torino and the passenger side manifold hit the frame on that side. I notched the frame for clearance then reinforced it, but it would be cleaner with headers or manifolds designed for truck use.
Old Dec 25, 2008 | 11:55 PM
1ole4d's Avatar
1ole4d
The truck has BBK equal length shorties on it right now. I know they'll bolt to the windsor. I'm just hoping there'll be enough room on the sides so I don't have to redo the exhaust (again).
Old Dec 26, 2008 | 09:06 PM
bmuhlbach's Avatar
bmuhlbach
I installed a 351w in my 68 oil pan only issue front sump drain plug right over cross member messy oil changes. i'm going to change to a rear sump pan.302 pans will not fit 351w.
