I have a 6" DR all spring kit on my truck. I recently purchased a set of firestone airbags, that mount on the inside of the frame and the axle tube because of my 5th wheel hitch. The rear spring pack is a DEAVER 5" (3-5000) eliminating the block completely...here is my dilemma:
The book suggested I purchase a 6" spacer for a 6" kit. I dry fitted the assembly and the spacer seems way too tall. I will probably fabricate my own spacer to fit. Does anyone have this same setup? What size spacer did you use?
