74 f100 4x4
thanx paul
There are many threads here on the "Highboy".
You can find many of them with the search function.
A few threads are linked below:
https://www.ford-trucks.com/forums/sh...hreadid=216562
https://www.ford-trucks.com/forums/sh...%25252Bhighboy
The basic definition seems to be:
A Hiboy is a Ford truck that came from the factory as having the following:
- Built from 1967 thru 1977.5.
- F-250.
- 4x4.
- Divorced transfer case.
Trucks that are NOT considered a Hiboy are:
- Any truck built after mid-1977. It goes by Consecutive Build Number in the VIN# anything built starting Y80001 is a 77 1/2. **
- Anything other than an F-250.
There will always be a couple very oddball exceptions but, for the most part, this is it.
Front axle choices in the Hiboy were either the 8 lug Dana 44 or the old style low-slung pinion Dana 60 (commonly referred to as the Dana 50). Engine choices were either the 6 cylinder or 360 2 bbl. Steering was either manual or power ram assist.
-Basic definition provided by user: BigBuddy
** VIN information provided by Dennis AKA Mil1ion.
It has been pointed out that the 300, 351M, and 400 were the engines available in the 77 model year.
The term High Boy, which is not Ford terminology, was originally coined by enthusiasts for 1973/76 and 1977 F250 4WD's (1977: last High Boy assembled before serial #Y20,001).
Some peeps refer to 1967/72 F250 4WD's as High Boy's.
1977: Y20,001 is the correct cut off serial number, it is not Y80,001.
This serial # info is direct the 1973/79 Ford truck parts catalog.
