Sponsored by: Kumho
removing a leaf
Old Apr 18, 2001 | 02:24 PM
beartracks's Avatar
beartracks
removing a leaf
Some time ago I had a leaf added to the rear springs and now don't use the camper any more and want to remove it myself. My concern is getting the through bolt out that holds the springs together. Is that sucker going to snap from the rust? Where to get one? What about the "nylon"(?) anti squeak insulators between the springs? Any advise appreciated.
1977 Ford F-100
400m/c6
280,000 miles
Stock on the outside
modified/rebuilt everything
Old Apr 19, 2001 | 06:57 AM
traildawg's Avatar
traildawg
removing a leaf
Just make sure to have a good sized C-Clamp on either side of the retaining bolt. This will keep all the tension off the bolt, and if it does happen to snap you won't be getting walloped by leaf springs and getting a ride in that tricked out van with pretty lights on top.
As for the nylon pieces, there should be a strip between each leaf, or caps on the ends of the leafs. just make sure they're still in place when you put it all back together and you'll be fine.
TrailDawg
https://www.ford-trucks.com/dcforum/User_files/3aaa4bac6f539876.jpg
1993 F150 2WD
4.9L-Auto
Pro-Comp Stage-2 6" lift
Auburn Pro-Series Diff. w/4.30:1 gears
35x12.50x15 General Grabber MT's
http://www.geocities.com/ProjectTrailDawg
Old Apr 19, 2001 | 09:50 AM
beartracks's Avatar
beartracks
removing a leaf
Thanks for the reminder on the "C" clamps!
1977 Ford F-100
400m/c6
280,000 miles
Old Apr 20, 2001 | 03:29 AM
kaulike's Avatar
kaulike
removing a leaf
