Sponsored by: Kumho
replacing brake hose problems
Old Dec 23, 2008 | 10:12 AM
yamaharider324's Avatar
yamaharider324
I've got a 78 f150 custom I6 4 speed and the rear brake hose blew out when bringing it home. It is the hose that goes from the frame rail to the axle.
Now the problem, I can't get the bolt even loose on the axle right where the block is! One day I tried heating it and that didn't even seem to help.
Anyway I can get this loose without breaking the bolt?
Old Dec 25, 2008 | 08:51 PM
rebocardo's Avatar
rebocardo
Spray with PB Blaster, cut the hose, put an impact socket on it and try a bit forward and backwards with a rocking motion, hold the block with a cresent wrench so you do not twist the block and attached lines.
Old Dec 27, 2008 | 12:33 PM
yamaharider324
Ok thank you I will have to give that a try very soon.
