Possible broken timing gears
Old Dec 22, 2008 | 09:23 PM
1982fordf100's Avatar
1982fordf100
A friend of mine has a 92 F150, with the 300 that wouldn't start yesterday. It was a very cold night. Zero degrees with a -22 wind chill. After a bit of trouble shooting the rotor in the distributor was not turning while cranking the engine over. I next looked down the oil filler port and the rocker arms where not moving while turning the engine over. I know ford went to the phenolic gears for the cam not sure about the crank though. I believe that has failed, but I haven't open the engine up yet. Is the 300 a non interference engine between the valve and pistons? I'm just hoping a piston didn't hit a valve. The plan is to replace the timing gears with all steel ones from comp cams. Any harm doing that on a EFI engine? Thanks, Fred.
Old Dec 22, 2008 | 09:38 PM
Bern_F150_4x4's Avatar
Bern_F150_4x4
I can't see why it would hurt, other than being noisy. Hope they last as long as Fords Phenolic ones
Old Dec 22, 2008 | 10:40 PM
Harte3's Avatar
Harte3
Cloyes also has a gear set available. As far as the noise goes. just tell everyone it's "blower whine". Some people pay big bucks for that sound.
Old Dec 23, 2008 | 06:25 PM
MintFord's Avatar
MintFord
I just rebuilt the 300 in my '90 F150 It had steel cam and crank gears in it when I took it apart. They didn't make any noise at all. They also didn't show any wear on their teeth. (I rebuilt because the cam bearings were worn out and I drove it for 6 months with no oil pressure) The rebuild kit also came with steel gears. There's no way I would put fiber ones in there when the steel ones work just fine without the risk of failure. I know a friend of mine replaced some broken phenolic gears in a late '80s 300 and the engine was ok.
FORDF250HDXLT
166
Jan 22, 2022 01:04 PM
glafond
Jan 4, 2017 02:58 PM
swglanville
401, 477, & 534 SD Engines
Oct 23, 2015 03:52 PM
shaker666
19
May 18, 2015 07:12 AM
Jeff92f150
21
Jan 28, 2008 12:38 PM
