vibration between 30 and 50
Old Dec 22, 2008 | 09:14 PM
1992f1504x4's Avatar
1992f1504x4
I am looking into buying a 1992 f150 and the owner says he thinks the vibration between 30 and 50 is u joints does this make sense and also what else could it be i dont want to buy a money pit just something to last the winter
Old Dec 22, 2008 | 10:03 PM
rainbowATF's Avatar
rainbowATF
Mine was 95 F150 with a 302 with 4R70W(AODE). My vibrations were bad fan clutch, motor mounts, u-joints, wheel bearings, driveshaft support bearing, and torque converter (OD clutch 20-50 mph). All this including tranny rebuild turned this dealer offered $3000 creampuff into a fine running $8000 machine. Enjoy it all the more in my poverty.
Old Dec 23, 2008 | 01:22 AM
lmd91343's Avatar
lmd91343
It could also be a front wheel out of balance.
Old Dec 23, 2008 | 02:40 AM
mattsautobody442's Avatar
mattsautobody442
if the trucks been ditched, the driveshaft may have rode along the shoulder, bending it, especially if it was at that speed when it happened, i did it myself, fell asleep withe cruise on in the rain, pulled out of it before i went in the ravine at 55mph, vibed at 55 ever since
Old Dec 23, 2008 | 07:46 AM
fmr9's Avatar
fmr9
My truck had a bent driveshaft when I got it, and a slight vibration between 35 and 50. After replacing driveshaft, ujoints, and front pinion carrier bearing, it is finally gone.
Good luck Frank
