Sponsored by: Kumho
front end lift?
Old May 12, 2001 | 12:31 PM
desperado_18_2000's Avatar
desperado_18_2000
front end lift?
just wondering, is there any way to lift my front end? i'm curious because i've got 31's on my truck and the front sits like maybe 2 inches above the tires. every time i hit a speedbump they hit the fenders. My dad suggested putting some 3/4 ton springs in the front... but i'm not so sure.. that would be the cheap way, thats not what i'm worried about..i'm just wondering if its safe and won't effect road handling.
1982 F-150 AOD 302
1976 f-100 Needs motor and tranny, lots more mods to come
[image]http://albums.photopoint.com/j/View?u=1667754&a=12880301&p=48237373.jpg[/image]
Old May 12, 2001 | 05:45 PM
billyb's Avatar
billyb
front end lift?
the lift kit guys offer front end leveling kits.
Old May 12, 2001 | 09:19 PM
murphydo's Avatar
murphydo
front end lift?
you should probably get new springs in the front. i had the same problem and i just got new suspension all the way around from some place that does major truck suspension for big rigs and stuff. i would hit a bump and the tires would rub and i would bounce up and down. The new springs brought the front end up about 2 3/4".
1987 F150 2wd
4.9L, 4 spd manual
31X10X15 BF's ATs
3" suspension lift
160,000 and counting
Old May 13, 2001 | 09:14 AM
traildawg's Avatar
traildawg
front end lift?
Most suspension companies now have leveling kits for teh frint, which is basically just new springs and shocks. As for the 3/4 ton springs, they'll bolt right in, but I don't know how it would affect ride quality. Either way you go, make sure to get an alignment when done, as your camber/caster will be off, and possibly more toe-in.
TrailDawg
https://www.ford-trucks.com/dcforum/User_files/3aaa4bac6f539876.jpg
1993 F150 2WD
6" Lift w/35's
And STILL waiting to get my 4.30 gears installed!!!!
http://www.geocities.com/ProjectTrailDawg
Old May 13, 2001 | 09:25 AM
traildawg's Avatar
traildawg
front end lift?
