Sponsored by: Kumho
rear end gear
Old Jun 13, 2001 | 11:55 PM
henryed1967's Avatar
henryed1967
rear end gear
I have a '92 F-150, w/ 302 cui, E4OD trans, 2WD, stock rear. I just up-sized my tires and wheels to a 32x11.5x15" and I've lost a lot of HP due to this. So it's time to change gears, any ideas on what size gear set I should use, I'm not very knowable in this area.
Old Jun 14, 2001 | 07:00 AM
lallen's Avatar
lallen
rear end gear
If you have 3.55, you should switch to 4.11. That is what I have read, someone else could confirm this.
Les
Old Jun 15, 2001 | 09:50 AM
henryed1967
rear end gear
yeah, thanks
Old Jun 15, 2001 | 10:34 PM
whaynes's Avatar
whaynes
rear end gear
If you plan on staying with 32 inch tires, 3.73 would be preferred unless you do a lot of rock crawling. If you plan on future upgrades including lift and 33-35inch tires you will probably want to go with 4.10's
WHaynes
93 F150 4.9L 4x4
4" ProComp StII Lift
BFG 33in 4.10's
Detroit TrueTrac's
Old Jun 18, 2001 | 02:24 PM
djdewey's Avatar
djdewey
rear end gear
