Odd one time only starting problem
Old Dec 21, 2008 | 04:24 PM
tag187's Avatar
tag187
I went to start the truck today, cranked it over and it acted like it was gonna start then just kept cranking, I let off the key and repeated this twice with the same results but this time whit smoke followed. Alass one more crank and it fired up like normal but with a hefty belch of white smoke then nothing and ran like normal. After five or six errands and five or six start ups still no issues. I put the truck on a good delphi scan tool and had no thrown codes. Any ideas, Injectors, valves?? As of right now I havent pulled the valve covers to see whats going on under there, so what you guys got. Thanks in advance.
Old Dec 21, 2008 | 05:00 PM
Bigfwt04's Avatar
Bigfwt04
I'm pretty new but it sounds like the glow plug relay is dying on you. Look up gpr led to test it, bdrummonds wrote a good thread on it.
Old Dec 21, 2008 | 05:20 PM
4inchlovin's Avatar
4inchlovin
Definitely a glow plug issue... Someone els will come along and tell you what...lol
Old Dec 21, 2008 | 05:23 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Probably not injectors or valves. Poor GP operation can cause this, as can failure of CPS to signal CI properly, as can a lack of fuel initially, though you did get some eventually as evidenced by the white smoke. Lack of ICP could cause a long start problem too if the HPOP reservoir is not full which looks like lack of fuel as mentioned.
Old Dec 21, 2008 | 06:10 PM
zx250's Avatar
zx250
Of the next Riffraff East
Weak batteries will cause hard starts along with all listed above.
