i own a 06 f-350 PSD and ive been having problem with boost when i step on the gas it will start to accell then about 20 sec the boost kicks in,also when i let off the turbo it makes a horrible sound and the gauge flutters down to zero when i let off,i was just w2ondering if it is my turbo vains sticking or it has to do with this cold weather here it was -35C when the problems started to happen
ya it has intestified cause i have never noticed the farting noise before a few days ago,egr should be good i only had the egr valve in for about 30000kms on it and so does the turbo
what was the fix? mine doin the same. -27*C after couple highway miles. no codes helpin dealer. they "cleaned" EBP plug but no help. im thinkin turbo vane issue
