Difficult Shifting 5-Speed
Old Dec 31, 2008 | 02:46 PM
live2wheel's Avatar
live2wheel
well, i installed the lil heim joint in my clutch pedal today. good fix . no play in the pedal now . the only problem is the safety start switch hits the lil heim joint and wont let me push the pedal all the way down ( about the last 1/4"). i've done away with this switch on other vehicles, but this one has 4 wires. anyone know how to bypass this switch? i'm thinking i'll end up breaking the switch by pushing the clutch in over time and the it wont start .
Old Dec 31, 2008 | 07:02 PM
arkredneck's Avatar
arkredneck
does anyone elses trucks trans sound like the gears are rattleing or the stick is rattleing when you get on it hard
Old Jan 1, 2009 | 01:24 AM
madpogue's Avatar
madpogue
That switch is actually two independent SPST switches in one "module", thus the four wires. According to my FSM, the green and tan/blue wires are for the clutch "interrupt" switch for the cruise control, which opens at the top of the pedal travel. The two red/blue wires are for the starter switch, which closes when the pedal is at the floor. You could try jumpering those two wires, and see if the truck starts regardless of the pedal position. Usual caveats, disclaimers, etc. apply; kids, don't try this at home, yada yada.
Old Jan 1, 2009 | 11:22 AM
live2wheel's Avatar
live2wheel
thanks for the info.
i forgot the cruise control is hooked up to the clutch . as it turns out when i cut the eye off of the clutch rod i cut it a little long. i was worried about cutting it too short. all it took was a little adjusting . no more hitting the switch. wow , the clutch feels real tight now.
dogerbrown1
47
Sep 8, 2024 10:47 PM
Caleb Petersen
19
Aug 29, 2019 05:55 AM
shultzaberger
1983 - 2012 Ranger & B-Series
17
Mar 30, 2016 07:47 AM
dnkensinger
Sep 25, 2015 10:31 PM
Bubba Jones
1978 - 1996 Big Bronco
16
Aug 20, 2013 01:22 PM
