1978 - 1996 Big Bronco
95 rear
Old Dec 21, 2008 | 08:31 AM
Cdy1's Avatar
Cdy1
95 rear
i canged the leafsrping brackets on my bronco and now whenever it rains and is wet when u turn it slams and pops in the rear, any ideas?
Old Dec 21, 2008 | 02:42 PM
greystreak92's Avatar
greystreak92
So you replaced the mounts AND shackles? I will assume they have been liberally supplied with lubrication at the bushings. Replacing the brackets is a serious ask. Especially since as I recall it, the brackets are riveted in place for the most part so there is no torque spec if bolts replaced them. If this is the case, I'd be checking that everything is still good and tight under there. I'd be doing it WITHOUT the weight of the truck on the rear suspension either.
Old Dec 21, 2008 | 02:57 PM
bronco94's Avatar
bronco94
Did you happen to change the shocks??
My 1979 ranchero did the same thing
replaced the shocks and the sound disappeared
Old Dec 21, 2008 | 05:24 PM
Cdy1's Avatar
Cdy1
no i replaced all 4 brackets neither of the shackles because they were in good shape, n yes i used bolts (grade 8 as recomended) and they are tight
Old Dec 22, 2008 | 12:37 AM
greystreak92
If the brackets were bad, what about the rest of the hardware? I guess my suggestion is that if the brackets were in that rotten condition, perhaps the other components are bad. They may not have been when the original work was done but now that they are the weaker parts they may have deteriorated.
baller9409
Jul 24, 2012 10:34 PM
fgials
Dec 21, 2011 05:52 PM
Skip1970
Mar 16, 2010 02:04 PM
geoaigel
Dec 18, 2002 06:42 PM
StockMan
Jun 4, 2002 08:39 PM
