If you do mean the upfitter toggle switch's the wires are left on top of the fuse box on the drivers side. You will need to lower the fuse box down and they are tied off with the harness. Just tie into them and you are good to go!
Upfitter switches are optional on the trucks. Ford will install 4 switches for use with accessories like aux lights, snow plows or air horns, if you check that option on the order form
The wiring is all there to do it yourself. You see Upfitter switch kits on ebay.
thanks i thought the wires were next to the brake booster
The wires next to the brake booster are "pass through" wires that you can use so you don't have to run your own wires through the firewall. the other ends of the pass through wires are also just behind your fusebox.
