More IDM woes
Old Dec 20, 2008 | 02:05 PM
97biostroke's Avatar
97biostroke
More IDM woes
So after my friends 01 stroke w/ 160k miles died while idling and threw an IDM code, we plugged the IDM into another truck, which wouldnt start. So The IDM was clearly the problem. Since my friends truck was not at home, we stole an IDM from another truck to get his home. He plugged in the other IDM and got it running, but now we have more problems. In his words, it runs like crap, is very loud, and sounds like its missing. It is also throwing the IDM code ( T1316 i think, same as before ), and an internal memory code which he says is from unplugging the wiring harnesses and plugging them back in. It had a rough idle before all this happened and didnt run the greatest, but now its worse than ever. Awhile back he run some very bad bio threw his truck and the glycerin plugged it all up, but after changing a couple filters and cleaning out the pick up pump it ran ok. Any ideas what could cause it to throw the codes again on a different IDM that works just fine and make it run like crap? Sorry its a long thread, but I want to give as much info as possible. Any help is greatly appreciated.
Old Dec 20, 2008 | 02:15 PM
F350-6's Avatar
F350-6
What are you using to pull the codes, and can it do any other tests? You need to look at doing an injector buzz test and cylinder contribution test to see if you've got a screwed up injector(s). You can also check for damaged wiring or a loose plug under the valve cover.
If you're using a tuner to pull the codes, try pulling both valve covers and check the wiring, then watch the oil discharge from each injector at idle. That will give you an idea if one or more of his injectors are not firing.
Old Dec 20, 2008 | 02:23 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Well, I was typing slow and watching TV. I agree with f350/Chris. Here is what I had typed:
My first guess would be a short somewhere that is causing the rough running. I would be afraid of burning up the borrowed IDM too until this problem is found.
Keep in mind that I am just guessing here, but I would start with a close inspection of the UVC harness (especially near the valve train) and go back from there. Good luck. Others who have had this problem may hopefully chime in.
Old Dec 20, 2008 | 02:24 PM
97biostroke
He's been using his superchips to pull codes, but he works at a tire shop and thats currently where his truck sits. He's got access to alot of tools and testing equipment so I'll tell him to try those tests. He did replace his #8 injector about six months ago. You think this could all be caused by some loose connections? What is an injector buzz test?
Old Dec 20, 2008 | 02:27 PM
97biostroke
Yeah i told him to take the other IDM in case somethin a short is causing his IDM to go bad. They're too expensive to be having to buy a couple at a time.
Old Dec 20, 2008 | 02:31 PM
Tenn01PSD350
A buzz test is a test of the electrical signal to the injector. It will buzz all of them, then each individually. Listen for any difference in sound.
Old Dec 20, 2008 | 02:32 PM
97biostroke
We did have the valve cover gaskets off a long time ago when we were checkin to see if the glow plugs were bad, but that wouldn't take a year to cause problems I wouldnt think.
Old Dec 20, 2008 | 03:27 PM
F350-6's Avatar
F350-6
If it's just a loose connector, it can be unrelated to the VC being off a year ago. Your comment about the glycerin in the bio has me worried. I don't know if that stuff would mess up an injector, but if you had to change the fuel filter several times, I could see some of the stuff in the fuel bowl making it's way past the filter during a change.
Unless the tire shop does work on a lot of diesels, the test equipment they have may not be of much use.
Old Dec 20, 2008 | 03:39 PM
97biostroke
He was pretty careful about keeping the junk from going past the filter, but is there anything else it could clog up and cause the fuel pressure to be low? I've read that there is a screen in the fuel pressure regulator, and we were gonna pull it, clean it, and shim the spring in case the fuel pressure was just low.
Old Dec 20, 2008 | 03:48 PM
F350-6's Avatar
F350-6
How thick is this glycerin? Would it plug up a screen? If so, then I'd check the fuel tank for the screen in the pick up tube, and the 2 little cylinder screens in the mixing chamber. I wouldn't think the FPR would be an issue unless there is something lodged in there that prevents it from increasing pressure.
A fuel restriction will typically show itself at top end or under load. The truck will usually idle fine all day long if it's a fuel pressure issue.
Old Dec 20, 2008 | 03:58 PM
97biostroke
It was about the viscosity of motor oil. He cleaned the screen in the pick up tube which was pretty dirty. Where would the 2 little cylinder screens be at? Are they hard to get to and clean out?
Old Dec 20, 2008 | 04:10 PM
F350-6's Avatar
F350-6
They're inside the white thing on the pick up tube. They're supposed to look like this
not like this
Just remember, I don't think this is related to your IDM codes or rough running. Just meant as an FYI that may prevent some future problem from appearing.
Let us know what you find on the CCT or by watching the oil discharge from the injectors.
Old Dec 20, 2008 | 04:12 PM
Tenn01PSD350
What screens are you talking about? There are screens in the restrictors where the fuel lines go into the heads. I even have pics of those out of the engine and partially disassembled in a write up I did of the stock fuel system a long time ago.
IDK why you think fuel is causing the IDM woes? Why not put a fuel gauge on it and see what it is doing?
LOL, multitasking and chasing Chris still.
Old Dec 20, 2008 | 05:11 PM
97biostroke
I don't think the two are related, but we were going to start looking for the problem of the rough running the day it quit, oddly enough. The main concern is the IDM codes, but while I'm at it i thought i'd try to fix em both lol. After driving it for a few min, the service engine light went off, but he hasn't tried clearin the codes and seeing what happens yet, he's at work so that wont be till later.
Old Dec 20, 2008 | 05:36 PM
ernesteugene's Avatar
ernesteugene
Look at the pic in post #14 here...
Messed with injector harnesses, SHAZZAM!
https://www.ford-trucks.com/forums/6...s-shazzam.html
... and check that you haven't rubbed through the insulation on one of those wires. You can also use the search word "UVC" and my username "ernesteugene" and search only the 7.3L forum and get more details!
In this thread, I mention the potential issue of PCMs needing to be mated with the appropriate IDM, and I'm not sure if you can mix and match with impunity!
https://www.ford-trucks.com/forums/6...y-running.html
