Sponsored by: Kumho
Noisy Leaf Springs
Old Jul 8, 2001 | 05:17 AM
frictition's Avatar
frictition
Noisy Leaf Springs
Hi, FYI, I'm sending this from Baku, Azerbaijan (formerly part of
the old Soviet Union. I have a 1992 F-150 XLT (Northland Edition)
with the 8 foot bed. The previous owner had a camper installed and seems like he added some extra leaf springs. I dont have the
camper but those noisy leaf springs are there. Any ideas on how to eliminate the noise without removing the springs (I have a
26 ft tow behind camper/trailer back in the states). Any resesonable suggestions are greatly appreciated.
Bob (First time Ford truck owner)
Old Jul 8, 2001 | 02:25 PM
karljay's Avatar
karljay
Noisy Leaf Springs
If the noise is from the rubbing of the springs together, I've heard of adding teflon strips between each spring to make them quiet. I heard that some spring shops offer this to help add more movement and better ride quality.
Old Jul 9, 2001 | 08:34 AM
frictition's Avatar
frictition
Noisy Leaf Springs
Thanks for the info. It definitely sounds like the springs are
clanging against each other. The roads are so rought you can
hear the truck coming 1/4 mile away. Will check out the spring
shops.
Old Jul 9, 2001 | 12:13 PM
Ford501's Avatar
Ford501
Noisy Leaf Springs
the noise is caused by the added leaf spring rubbing against the main spring as shops dont install the teflon in between each leaf as they definately should
i have the same problem with my 95
Old Jul 9, 2001 | 09:10 PM
frictition's Avatar
frictition
Noisy Leaf Springs
Anybdoy know where to get the teflon and how much it costs,
not to mention is it difficult. Being over here in part of
former Russia it isnt that easy to get things fixed or done.
Ill have to probably order whatever is needed via the net.
Old Jul 16, 2001 | 04:44 PM
tetraruby's Avatar
tetraruby
Noisy Leaf Springs
How about a little lubricating oil between the leaves?
Old Jul 16, 2001 | 06:24 PM
85351ho's Avatar
85351ho
Noisy Leaf Springs
bigb56
Sep 8, 2014 09:04 AM
nutmg1
Aug 15, 2011 09:47 PM
ekimg37
22
Jun 19, 2008 10:18 AM
78f250_rls
Offroad & 4x4
Apr 6, 2008 11:57 PM
VolvoWrench
Jul 14, 2004 01:46 PM
