'94 F-150 engine stumbling
Old Dec 19, 2008 | 03:06 PM
dr1's Avatar
dr1
ok I'm being lazy here, but I figured while im eating my dinner and getting warm I'll throw this out there and maybe get some ideas :P
I was out for about 45 minutes today in the snow storm when my check engine light came on, no idea why until a bit later I noticed it was stumbling under load.. I was having to run a gear lower going up hills and had to be pretty easy on the pedal or the engine would shake me to death. I thought it was wheel hop at first, then im like.. wtf im in the snow, with 4x4 on no less...
If I tried to floor it, it would just try to cut out completely.
I switched tanks and that had no effect on the problem.
I'll check the code tommorow.. my luck it will be code 18974 - "your engine sux, plz fix".
Old Dec 19, 2008 | 10:35 PM
ma94xlt's Avatar
ma94xlt
When is last time it had basic tune up? Thats where I would start,, check the cap, wires, rotor, plugs and fuel filter.. If you dont have a code..
Old Dec 20, 2008 | 06:39 AM
Lazy K's Avatar
Lazy K
Good advice but get the codes. Probably an EGR valve problem but you need the codes.
Old Dec 20, 2008 | 02:25 PM
frankyford's Avatar
frankyford
If it's not the EGR after the tune up try your air/idle bypass valve. Also probably a good idea to spray some carb cleaner in the TB.
Old Dec 22, 2008 | 02:32 PM
dr1's Avatar
dr1
Been sick all weekend so havent messed with it. Just went out and check the codes and I got 172 (it seemed to come up twice is that normal?) and my book lists that as 'HEGO shows system always lean'
So yeah kind of a useless code like I figured.. :P
I guess I'll try a fuel filter first..
Old Dec 23, 2008 | 02:43 AM
mattsautobody442's Avatar
mattsautobody442
i had that exact same problem, it's your tps, cuts out when the cel comes on? thats the issue when going down the road.. if it stumbles when leaving a light, its the IAC. if its both symptoms, its both parts, especially if they've never been changed.
