small trans leak any tips?
Old Dec 18, 2008 | 03:32 PM
84 f250 6.9's Avatar
84 f250 6.9
hey i got my junkyard trans in and now everything runs PERFECTLY except for when im done drivin it it leaks a lil trans fluid not alot jus a lil in the middle piece between the trans and transfer case is there a quick fix? cuz i tightened all the bolts after driving for first time an it helped a lil but it still leaks some
Old Dec 18, 2008 | 04:26 PM
rupejosh's Avatar
rupejosh
you could always put some gasket sealer on it if ya want a quick fix just clean the area real good.i think lucas makes a tranny treatment that helps seal up leaks
Old Dec 18, 2008 | 05:06 PM
PLC7.3's Avatar
PLC7.3
What trans.... C6 has a gasket between the 4x4 extension and the main body.
Old Dec 19, 2008 | 06:13 PM
starmilt's Avatar
starmilt
He has a t19 the only real fix is pull the transfercase and reseal it.
Silicone works wonders just dont get carried away with it.
Old Dec 20, 2008 | 11:17 PM
S.P.'s Avatar
S.P.
Talking
Try Yammabond from the Yammaha dealer...works good to seal a dirt bike case...
