Trans issues
Old Dec 18, 2008 | 01:18 AM
randomhero1172's Avatar
randomhero1172
Originally Posted by David85
That would be the first thing I would check. Alternator and vacuum pump belts.
What are your power brakes doing? are they affected at all?
Power brakes, fine. alternator - just tested friday and tested good, its fairlynew! (unrelated problem) which belt is the vacuum belt, which is the vacuum pump?
Old Dec 18, 2008 | 01:20 AM
joe f350's Avatar
joe f350
look for duble pullys mine vpump is under altnaer
Old Dec 18, 2008 | 02:43 PM
Lead_Pusher's Avatar
Lead_Pusher
As stated vaccum pump is under your alternater, and is driven off the double pully. If the belts are tight you might want to do a vaccum test of your Vaccum Regulator valvue black plastic thing on driver's side of IP has two vaccuum line running to it. I found the test on this site and did it on my 88. Mine wouldn't shift into 2nd, I adjusted it and it works fine now.
Old Dec 18, 2008 | 03:29 PM
randomhero1172
Anyone have a link on how to test it? tools needeD? etc...thanks!
Old Dec 23, 2008 | 04:46 PM
ford trans tech's Avatar
ford trans tech
first of all does it shift normally from 1st to second
if it does it isnt a vaccum issue
how is reverse , is it normal or does it slip in reverse
several internal issues can cause the loss of third gear
a c-6 in a 1990 is not that uncommon ans is normal on commercial units especially uhaul they specified c-6 to reduce the cost of the truck and they dont worry about your fuel economy when renting
