Stonger Power Steering
Old Dec 17, 2008 | 10:38 PM
darkfall13's Avatar
darkfall13
Hey all,
Thanks for the A/C help previously but now I want to know more about the power steering setup in the '99 F-250. My dad, though a big guy, knows he's getting up there in age and is starting to find it more and more difficult to get the wheels pointed in the right direction when not moving. I found a new pump from AGR that might take care of that problem. But he wants me to find some simpler routes before investing in that. Is there something else that can be done like allowing more pressure to the system or maybe a different size pulley to get the pump spinning faster.
Oh as a side note, has anyone ever had a problem with the truck moving to the left when braking? I drove it today and it was doing that, but from what I saw the pads still have plenty of meat, and the rotor is not scored in any way.
Old Dec 18, 2008 | 12:53 AM
Tenn01PSD350's Avatar
Tenn01PSD350
My stock system is still doing fine. I need to flush it with some synthetic. Why would you think you need another (aftermarket) pump unless you have huge tires and a lift?
Oh, that pulling to the left is a problem. Did you know the same system that powers the steering powers the brakes? I believe I would be looking real close at the brakes. Especially the right side.
Others can chime in but I am bumping you to the top.
Old Dec 18, 2008 | 05:59 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
You could flush the system with synthetic ATF. This has helped people before. As far as your pulling to the left, I would check to be sure his slide pins on the calipers are not stuck. Here is how to do this. click here. I would also bleed the brakes.
Good luck.
Old Dec 18, 2008 | 05:01 PM
darkfall13's Avatar
darkfall13
Yeah I wouldn't want to go the pump route either, but that was all I had found relating to the problem so far. I told him about flushing and replacing with synthetic and he's got it on his to do list now.
