94 E4OD problem
Old Dec 17, 2008 | 07:55 PM
rob rosencrans's Avatar
rob rosencrans
94 E4OD problem
My 94 F150 4x4 is shifting into all gears hard. I reset the computer and it goes ok for about 50 miles and then does it again. The shop told me that something is making it defaukt to high pressure. The tranny shops around here are kinda shady so i don't trust them they all just want to rebuild for 2K.
I don't know what the codes are that I assume are being stored, but does anyone have any thoughts on this. Could it be just a sensor? I don't notice any slipping just hard shifting.
Old Dec 17, 2008 | 08:14 PM
danr1's Avatar
danr1
Instead of just resetting, clearing the computers memory run the self test and retrieve any and all codes, only then can you begin to fix the problem.
And yea to answer your question, it could be any number of small issues, easy to fix issues, that are causing what you describe.
But you have to start by finding out what the computer knows about it first.
Old Dec 17, 2008 | 08:59 PM
924x2150's Avatar
924x2150
there is a sensor on the drivers side, I forget the name..maybe manual lever shift position sensor. Anyway, it is a bunch of resistors, a voltage divider, that simply notifies the computer what gear u selected. Ford issued a tech service bulletin about that module and harness, and that part can cause erratic shifts. The harness and module were erratic because of moisture and corrosion, the new part was developed to overcome that.
BY ALL MEANS GET THE codes! They are important..The E4OD is pretty tough, but electronically controlled. Get to your very trusted mechanic, and don't do anything until u can get a good diagnosis, then ask us first b4 u OK a big repair.
If you learn to retrieve your codes you'll have a big advantage over the repair shops...all u need for a 94 is a paper clip and pencil and paper to get the codes from your dashboard check engine light. see fordfuelinjection.com and buy a haynes manual..the code retrieval procedure is in that book too.
Old Dec 18, 2008 | 03:13 PM
rob rosencrans
Thanks guys for the help. I will pull the codes the next time it happens and go from there.
Old Dec 18, 2008 | 04:02 PM
skaterbro's Avatar
skaterbro
Why wait? Pull codes next time you're in your truck. It'll take all of 2 minutes.
