Injector replacement
ffice
ffice" /><o
></o
><o
> </o
>Anyhow I have a 2000 7.3 and the #8 injector has failed. Or at least that’s what the service advisor believes. He said it could be the harness or the injector, but everything I read about tells me that it’s the injector. I decided to not have Ford do the work and I was going to get a remanufactured injector but I was wondering if I should replace all of the injectors? I have 170K on the truck and I don’t want to have to go in twice. I found the injectors from injectorwarehouse and they are 149.00 each.<o
></o
><o
> </o
>Your comments are appreciated.<o
></o
><o
> </o
><o
> </o
>Thanks<o
></o
><o
> </o
><o
> </o
>Mike <o
></o
If you want to stick with stock injectors, the best option is a NEW Alliant injector- remans can be temperamental and don't always work right. Replacing just the bad injector is fine, as long as the rest check out okay, a couple of tests (cylinder contribution and buzz test) can help determine if the rest of them are good. Since I don't know much about this stuff I'll leave it at that... welcome to FTE and hopefully we'll have you back on the road soon!
Mike, I concur with Chase. Replace the injector with a NEW Alliant injector. However, not the required long lead injector Ford used in the #8 cylinder.
Stick around.
Reguardless I would track down the problem. Remove Valve cover and inspect wiring harness both under VC and outside of it. Trace the wires looking for burnt or chaffing. Then verify the plug pins are in good shape. You can crank the truck at this time if you want and you can see the oil squirting out of each injector as it runs. If one is not squirting that is the culprit. Matter of fact you may want to do this anyway to verify that it actually is the #8 injector. And don't worry changing them is easy.
BTW Welcome to FTE
