Sponsored by: Kumho
Power brake conversion for '73?
Old Aug 17, 2001 | 05:07 PM
rudifisk's Avatar
rudifisk
Howdy all,
Can anyone tell me what booster and master cylinder will work with my '73 F-100? It has front discs with standard brakes right now. Will car units bolt up? I know of a '68 Thunderbird unit at the wreckers, could that possibly work? Thanks.
Randy Howard
Old Aug 17, 2001 | 11:57 PM
karljay's Avatar
karljay
I converted from std to power brakes on my 73 F250 4x4 with 4 drums. I found two types of boosters, one large pancake looking one with an adapter that raised it a few inches, and another twice as thick and about 8" dia with an adapter that didn't raise it at all.
With research, I found that the small thick one was the heavy duty one and then I verified the length of the rod inside and set it to factory specs. It works great, simple clean install.
I'd say if the rod length is proper, it should work. If you can't get a return policy, I'd pass and get one from a truck. You may even want to get a rebuilt one from a parts house, I don't think they are very expensive.
Old Aug 18, 2001 | 10:01 AM
weldman's Avatar
weldman
HMS
Jan 24, 2016 01:05 PM
ct50f1
Oct 20, 2015 09:41 AM
engine14
Mar 27, 2014 02:16 PM
engine14
Mar 26, 2014 02:55 PM
engine14
New Member Introductions
Mar 25, 2014 08:01 PM
