slider rear window
Old Dec 16, 2008 | 11:30 PM
Langford Ford's Avatar
Langford Ford
slider rear window
Does anyone know what years the sliding rear window in a 1990 Ranger cross over to and are the Mazda windows the same? Thanks
Old Dec 17, 2008 | 01:10 AM
Rangerman Stan's Avatar
Rangerman Stan
The sliding rear window in the 90 Ranger should fit other Rangers from 1983 to 1992. Keep in mind that the rear window on the supercab is larger than the regular cab rear window. The 3rd generation body change occurred in 1993. However, it's possible that the 1990 window will fit a Ranger newer than 1993 or vise versa. You could check with a glass shop to check for interchange possibilities. Mazda "B" series trucks didn't start to share parts with the Ranger until 1994. Up till then they are a whole different truck.
Old Dec 17, 2008 | 05:06 AM
wendell borror's Avatar
wendell borror
Yeap, what he said.
Old Dec 17, 2008 | 09:58 PM
Langford Ford
Thanks for your help.
Old Dec 18, 2008 | 11:35 PM
michigan66's Avatar
michigan66
Rear sliding windows from '83 to '97 are all the same for standard cabs. Super cabs from '86 to '97 are the same. That same window (SCab) is used in '98 to '05 Rangers.
Old Dec 20, 2008 | 01:14 AM
Langford Ford
Smile
Thanks, just so I am clear the slider window fits from 86 - 97 and also the 98 -05? Do they also share the same weatherstrip for around the window for all those years? Thanks for everones help.
Old Dec 20, 2008 | 03:58 AM
michigan66's Avatar
michigan66
'83 to '97 Standard cab - all use the same slider window
'86 to '97 Super Cab - all use the same slider window. This window is different
from the '83 to '97 Standard Cab window.
'98 to '05 Standard Cab use the same window as the '86 to '97 Super Cab.
The same holds true for the rear window rubber weatherstrip. All of this info is according to the LMC Truck catalog.
tallon64
Oct 10, 2011 08:39 PM
06RANGER
31
Jan 9, 2006 06:05 AM
seagull369
Nov 12, 2003 06:12 AM
Mazda96
Oct 14, 2003 01:08 PM
