gear venders
Old Dec 16, 2008 | 05:59 PM
symonds86's Avatar
symonds86
gear venders
i have a chance to get a gearvenders od unit cheap, its off a 2wd zf mines a 4wd with the zf. is there any way to put this on a 4wd? i no driveshafts would have to be shortened and leanthened, but any help would be great
Old Dec 16, 2008 | 07:20 PM
royzell's Avatar
royzell
You would need a different adapter to hook up to the transfer case instead of the tranny.
Those can be bought direct from GV, check thier site for prices. I would check that you have all the electronics as well.
Old Dec 16, 2008 | 08:23 PM
symonds86's Avatar
symonds86
ok thanks, i have to pull the uit myself so i can makesure i get all the electrical stuff
Old Dec 17, 2008 | 06:00 AM
fonefiddy's Avatar
fonefiddy
Kinda crazy what their adapters cost. Like $4-500
Old Dec 17, 2008 | 11:12 AM
Dave Sponaugle's Avatar
Dave Sponaugle
The other option is a divorced transfer case.
My guess is you will need more electronics as well, the 4x4 model locks the Gear Vendors unit out when in 4x4.
I can also tell you that on the 1345 transfer case, you replace the rear transfer case housing.
I just looked, they only show a slip joint drive shaft connection for the 1345, so that means new custom driveshaft unless they have other parts not listed.
