Sponsored by: Kumho
Helper (leaf)Springs
Old Dec 16, 2008 | 05:50 PM
awilsonF250's Avatar
awilsonF250
So, who has any experience with using helper springs on their truck? I have wondered about the progressive rate ones that do not affect your normal driving, but come into play as you load the vehicle. Is this a cheep and effective way to help combat heavy bed loads and trailering?
Old Dec 19, 2008 | 07:25 AM
Lou Braun's Avatar
Lou Braun
Helper springs work but stiffen up your ride significantly even if they are sold as "progressive".
For the front end I'd consider replacement stock springs in a higher spring rate instead of any sort of helper spring. For the rear end consider using air bags. These can be inflated when you need the load carrying capability and deflated when you don't need to carry a load.
Lou Braun
boulderbronco
6.4L Power Stroke Diesel
Oct 29, 2010 08:30 PM
mason346
Sep 4, 2010 04:27 PM
trike1946
May 11, 2007 08:34 PM
Narwhal
Apr 7, 2004 09:30 AM
1w_racer
All Things Towing
Sep 26, 2002 05:08 AM
