Sponsored by: Kumho
Wheel width vs. Tire width
Old Sep 2, 2001 | 03:13 AM
thoseapples's Avatar
thoseapples
Would 235/85R16's be wide enough to mount safely on an 8" wheel, or would sticking them to a 7" wheel be a wiser choice?
Jay
'93 F-150 XLT
Old Sep 2, 2001 | 11:50 AM
StrangeRanger's Avatar
StrangeRanger
BFG recommends a 6"-7" wide rim with that tire size, other manufacturers may vary. If you really want that 31-3/4 diameter and need to use the 8" rims, try a LT265/75-16.
Old Sep 2, 2001 | 08:23 PM
thoseapples
Thanks for the info!
That's a good idea, however I'm trying to stick with the 235's if possible. Plan is to put F-250 spec running gear on my F-150 with custom rims.
Would 265/85-16's rub the radius arms or fender wells?
Jay
'93 F-150 XLT
Old Sep 2, 2001 | 09:10 PM
StrangeRanger
265/85-16s are HUGE, about 33.7" dia. Depending on wheel offset, they'd probably rub somewhere. 265/75-16s are approximately the same diameter as your 235/85-16s about 31.7" If you've got 3/8" or more clearance with the 235s, the wider 265s should fit
Old Sep 3, 2001 | 06:36 PM
thoseapples
That was my typo, I meant 75 for the aspect ratio! Until now I was unaware of the 265/75R16 as another option for the 8" rims, and I think I've decided on just that. Thanks for all the help!
Jay
'93 F-150 XLT
Old Sep 4, 2001 | 12:08 AM
slimersoup's Avatar
slimersoup
apachetech
Mar 6, 2015 06:50 PM
Osiyo59
Feb 2, 2015 05:09 AM
brittanniwolfe0
Jul 5, 2012 05:04 PM
racetrips
May 16, 2005 12:48 PM
MRHIGHSPEED
Dec 20, 2002 08:56 AM
