Adding a plug-in heater?
After my eye appointment at the VAMC, I contacted my Ford parts-guy, service-gal and mechanic that I trust. I explained what was happening (or not happening in this case), what I had done and what we discussed here at FTE.
The mechanic said it was most likely the element, since the cords sounded good. The parts-guy had an element in stock for $51. I talked him down to $38. When I went to pay for it, I gave the cahier my "Owner's Advantage" number to see if I had anything available. I didn't think I did, but she said I had 44 points available. I used some of my points and the item was free.
I do need to go to the "tool" store to buy a 1-1/8" deep-well socket to do the R&R. Hopefully, I can get the truck started for the rest of this week so I can do the R&R this weekend.
I changed my GPR while it was snowing. High temps for this week will be in the teens and low-20s with more fluffy stuff coming in by this weekend. I don't have a place big enough to do this indoors, so I forced to do it outside. I need the engine cooled off for the swap. I have to relieve the cooling system pressure before trying to swap out the heating element. Hopefully, my fingers won't be too frozen and I won't loose too much coolant.
Thanks for everyone's help on this. I appreciate it.
Mine always reads in the cold range. After 3 hours plugged in it just barely moves but the "Wait to Start Light" tells the story. The only other thing I can think of is make sure you have a heavy duty extension and not one of those really small diameter ones. 15 ohms is right on target.
I don't know what temps you're seeing over there, but we've been down into the teens. Before this problem, my truck gauge would read at or above "N" after being plugged in for four hours. Have you tested your's lately? Maybe you're at the beginning of a problem.
Jim, tried to rep you after the other two, but still gotta spread the love around.
That being said .. maybe I do have issues and just never knew it. I would be interested in other opinions and their experiences.
Good tip!
Does anyone know how much power these block heaters pull as far as the electricity bill? Just curious. I know the amount is reduced once the water jacket is warm.
Just doing some thinking if it's worth keeping a diesel running verse plugging it in. However, if you can plug it in I'm sure it's much cheaper.
#29
Actually, it's sold in kilowatt-hours -- power * time = energy (remember unit analysis from high school chemistry/physics?). And the cost, of course, varies wildly by location. Here, we pay about US$0.13 / kWH, so about 39 cents to run it for 3 hours. Your cost per kWH should be on your electric bil (granted, deciphering the bill is a black art, compared to the otherwise simple math involved).
#30
Thats for the clarification. I took some pretty tough chemistry/physics courses in college but I never had to apply the information...
Anyways running the block heater is cheap.
