Sponsored by: Kumho
Rear spring shackle flip
Old Aug 26, 2001 | 10:34 PM
jeff03's Avatar
jeff03
Has anyone flipped the rear spring shackles on and f250. How much lift does it provide? What are the pro's and con's to this? Also what about lengthening the front spring shackles to get a little lift in the fron?
Old Aug 26, 2001 | 10:40 PM
85351ho's Avatar
85351ho
for every inch of shackle you add, you get .5 inches of lift
1985 F-150/351Ho/c6/4wd~94,000 miles
1979 F-150extcab4x4/460/c6/6inchlift w/60rear44frnt (250 axles and springs)
37 inch boggers
Old Sep 13, 2001 | 11:15 PM
broncoman85's Avatar
broncoman85
Flipped them on a Bronco, never had any problem. I ground the rivets off and replaced them with grade 8 bolts. I've heard that you can have trouble with the springs over arching on an off camber situation and jamming to the front, I never had it happen and I put that truck through heck....but don't say I didn't warn you lol. Seems like I've read about welding a stop on the shackle bracket to stop this...just never had to do it myself. Whit
Old Sep 14, 2001 | 01:19 AM
weldman's Avatar
weldman
