glow plug relay ???????
Old Dec 15, 2008 | 08:46 PM
Gassports's Avatar
Gassports
What is a good brand,and where is a good place to buy it??
Old Dec 15, 2008 | 09:05 PM
F350-6's Avatar
F350-6
You can get a 109 relay from Napa, or you can upgrade to a big relay if you are looking for something more robust.
Welcome to guzzle's Stancor GPR replacement Mod Web Page
Old Dec 15, 2008 | 10:41 PM
Eric H's Avatar
Eric H
I recently replaced mine with a GPR-109 from Napa. The mounts are shifted 90-degrees, but the wires are long enough to reach.
Old Dec 16, 2008 | 08:01 AM
BigJake34452's Avatar
BigJake34452
is the gpr109 a direct replacement? no need to do anything besides put it in?
Old Dec 16, 2008 | 08:13 AM
Ponyboychris's Avatar
Ponyboychris
GPR109 from Napa is a sorta direct replacement. Like Eric says, it's the same relay but the terminals are 90 degrees off. I think the GPR110 is the direct replacement but it is way more expensive so most folks use the GPR109. I was able to find a motorcraft replacment on ebay but I bet they are hard to find at this time of the year - being cold out.
Eric H's Avatar
Eric H
It's direct besides being rotated 90-degrees, and is cheaper than the model they will try to sell you for our trucks.
Old Dec 16, 2008 | 09:05 AM
BigJake34452
good deal, 109 it is
Old Dec 16, 2008 | 09:15 AM
jdecker88's Avatar
jdecker88
I just put my stancor unit in last week and I love how it looks and works. It was worth it for me to know it will work.
Old Dec 16, 2008 | 09:41 AM
Ponyboychris
The Stancor relay swap is on my radar after the holidays.
Old Dec 16, 2008 | 09:57 AM
jdecker88's Avatar
jdecker88
IT is tight and gets a little interesting putting the wires back on it but they work.
Old Dec 16, 2008 | 10:08 AM
Ponyboychris
Thanks, good to know. I assume you mounted it the same way as Guzzle, correct?
Old Dec 16, 2008 | 10:11 AM
Smokin''s Avatar
Smokin'
Smokin
Just be careful when you put it on. Open ended wrench only, no sockets.
They are a bit delicate, they are just made out of plastic. Especially with the 109, the unit is rotated 90 degrees like the guys said. Everything will reach to the posts but it puts extra pressure on the relay itself.
Old Dec 16, 2008 | 10:26 AM
jdecker88's Avatar
jdecker88
Correct Chris, follow his instructions because it is very tight.
Old Dec 16, 2008 | 10:28 AM
Ponyboychris
Thanks again, Reps sent - finally!
