Offroad & 4x4
31 spline 8.8
Old Dec 15, 2008 | 11:39 AM
ajm859830's Avatar
ajm859830
31 spline 8.8
Im lookin to pick up some 31 spline axles for an 8.8 from the junk yard and was wondering if someone might have a suggestion as to what kind of truck/suv I need to look into for some. Ive heard of explorers having them iirc. Thanks.
Old Dec 16, 2008 | 05:03 PM
Ryan50hrl's Avatar
Ryan50hrl
your a month late....i just sent the set i had to the scrap yard
Old Dec 16, 2008 | 05:04 PM
Ryan50hrl's Avatar
Ryan50hrl
what axle housing are you putting them in, they're available in different widths. V8 explorers had them, F-150's had them, and if i'm not mistaken, you could also find them in V-6 rangers of later model years.....but don't quote me on the last one....
Old Dec 16, 2008 | 06:48 PM
ajm859830's Avatar
ajm859830
01 mustang, lookin to go with a 31 spline axle/trac loc vs the 28
Old Dec 16, 2008 | 08:12 PM
Ryan50hrl's Avatar
Ryan50hrl
Those may be the same width as explorers....but truck axles will be too wide....what are you running for power?
Old Dec 16, 2008 | 09:14 PM
06silvercrew's Avatar
06silvercrew
No they are differnet all together. 99-04 mustang is the only thing that is going to work. 79-93 is one length, 94-98 is one lenght and 99-04. All explorers and trucks with an 8.8 had a 31 spline trac lock. Too bad, Just sold a set of 31 spline strange axles with 3'' screw in ARP studs and a 03/04 cobra trac lock with carbon fiber clutches and extra shims all from my '03 GT.
Old Dec 23, 2008 | 06:34 PM
ajm859830's Avatar
ajm859830
As far as the differential one out of a truck/suv/etc should work though correct. As im guessing they have the same housings?
Old Dec 25, 2008 | 07:57 PM
06silvercrew
Yupp, even if it has IRS it will work. The 03/04 cobra is most desirable as it has carbon fiber clutches, 31 spline. But any truck or explorer will work. Not 100% sure if the rangers with 8.8 were 31 spline or not.
Old Dec 31, 2008 | 05:59 PM
894fseries's Avatar
894fseries
I've heard that you can use 1 side of a ranger rearend. NOT sure 1 side and not both but I got some 8.8 parts ( gears, ected)
Old Jan 1, 2009 | 08:02 AM
06silvercrew
You can use 2 LH ranger axles in the earlier cars, but NOT in a 99-04. They are much wider then all the others (about 2 inches)
Old Jan 5, 2009 | 10:25 AM
live 2b offroad's Avatar
live 2b offroad
rangers have 28 spile 8.8s they actualy use the same axle as a 7.5
ALL explorers have 31 spline.
and if your looking to put these in a mustang then length im not sure of. but most mustangs as far as i know had 28 spline. i dont know mustangs but i do know RBVs
and you cant put 31 spline axles in a 28 spline housing. bearings sizes are different.
Old Jan 5, 2009 | 10:36 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 06silvercrew
79-93 is one length, 94-98 is one length and 99-04.
There was no such thing as an 8.8 until 1983.
Not all F150's and Explorers have Trac-Lok, as it's an option.
Prolly 60% or more of these vehicles do not have Trac-Lok.
Old Jan 5, 2009 | 08:45 PM
06silvercrew
You are correct. I was stating that the fox body was all the same length.
You are also correct about they dont all have trac-lok, I probably wasnt clear on that. I was trying to say that if it was a truck or explorer it had 31 splines...trak-lok or not. 03-04 cobra was the only car that I know of that had 31 from the factory.
Old Jan 5, 2009 | 08:52 PM
06silvercrew
Thanks for clearing that up, I was unsure if the ranger had 28 or 31 in the 8.8
You are correct all mustangs with the exception of 03/04 cobras are 28.
As far as not being able to put 31 spline axles in a 28 spline housing....May be the case with a ranger....I have no idea.... BUT on a mustang that is NOT the case. I build them all the time for guys with no problems. But granted I use Srange axles so that my be the difference?
Old Jan 6, 2009 | 02:27 AM
NumberDummy
Does the vehicle have Trac-Lok (Limited Slip)?
If the AXLE code listed on the Certification Label begins with a letter, it has Limited Slip.
If the AXLE code begins with a number = NO Limited Slip.
This has been the case since 1959, the first year Ford offered Limited Slip, which back then was called Equa-Lok.
Madmike33
Jul 25, 2008 08:59 PM
bsprowl
Jul 30, 2007 01:26 PM
bsakal
Jan 13, 2007 01:10 PM
sternal2000
Oct 1, 2001 08:24 PM
