My sons truck, it is several hundred miles away, so I work on it when I can..it died a few months ago. No Spark, checked the coil, changed cap and rotor, AutoZone checked the ignition module. At some point we noticed that the fuel pump was not running either so I changed tactics and checked the EEC relay, replaced it no change, I can feel/hear the relay engaging. Just for GPs i pulled both the EEC and fuel pump relay and jumpered accross. The fuel pump started humming but still no ignition. any ideas?
I suspect the PIP(profile ignition pickup) inside the distributor has died. I would pull the distributor and take it to a Ford dealer, they can check to see if the PIP is bad before disassembling the distributor to replace the PIP. And I don't recommend a rebuilt distributor, I have learned from these forums that rebuilt distributors are, for the most part, JUNK.
don't trust autozone parts or advice.
read codes.
how did you check coil?
replace relays, do not jump them.
is fuel pump on for a couple of seconds? or does it stay on?
also, why did it die? exactly what happened. why so long to get to it?
I checked the coil by checking voltage with a DMM on the Red/Lt Green wire and the Tan/Yellow wire...battery level voltage on both
Fuel pump stays on when I jumpered the relay
I was not there when it broke, my son said he was driving it and it died on the road
My son is away at college and i just have not had the time to get to it since it is 3 hours away. I have been down there several times but have not had any success.
The timing signal from the distributor is what the computer uses to determine if the engine is running and when to turn on the fuel pump. Does the fuel pump run for a couple seconds after turning the key to "run" or does it not run at all? If you ground the fuel pump wire in the diagnostic connector, that will force the fuel pump relay to energize, which will tell you if the fuel pump relay is working properly.
Here is a link that shows how to get the codes with a paperclip - just leave out the voltmeter/test light and watch the check engine light blink: EEC IV Self Test hookup . I believe the fuel pump wire is #6 in the diagram on the linked page.
